clutch change with jack stands?
it can be done... takes a little more effort but if you dont mind laying on your back and got a friend that can help you should be good.... did my step dads last week on 3 tons and wheel ramps
actually here is a pic of the car half way through
![](http://i25.photobucket.com/albums/c61/navymitch12/Home%20Pics/P1040680.jpg)
any lower than this and it might have been an issue getting the tranny out but we had no real problems
Originally Posted by ss1129
I even got to watch the 700r4 roll onto my friends head. I will never forget the noise he made.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
no access to a lift so its jack stands it is.
I been to two transmissions shop's around my area with other vehicles and not happy with with service and there master
idiots
example: Who would change a new clutch&flywheel in a 97 neon and not change the throwout bearing and in less than 3000miles charge me $250 to change it
navymitch12 that pic reminds me of the QTP header install
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
My buddy and I did it on my car yesterday... the fun part is bench-pressing everything back into place when you're done. Oh, and watch out for your *****. Its was a new experience having to remove the mounting bracket from my friends zipper.
Tranny is over 100lbs...
I put a jack under the tranny, roll it under the car, and jack it up. takes 2 people. One to jack and stabalize tailshaft of tranny, and the other to stabilize the front/sides and guide it in.
Had thought about a trans jack, but don't feel like spending $300 on something I'll (hopefully) use once every 3-4 years at most.
