Question after clutch install ??
Old Apr 28, 2002 | 11:00 PM
Billy C's Avatar
Default Question after clutch install ??
Hey guys , I installed my new ZO6 clutch , flywheel , slave cyl. , I put about 250 miles on it and decided to give her a little "TEST" <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Anyway , I have a loud BANG under the car when I shift her hard , and she wheel hops BAD , It has never done this before so Im a little worried I may have screwed somthing up on the install , My car only has 21,000 miles on it and the tranny mount look ok when I had it out , Any Ideas ???
Old Apr 28, 2002 | 11:05 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Question after clutch install ??
Sounds like the y-pipe is hitting the floorboard. Also, make sure the tranny mount is not torn or not torqued down properly. Double check the torque arm mount as well.
Old Apr 28, 2002 | 11:18 PM
Billy C's Avatar
whoops !! when you say tourqed down properly , What do you mean ? I was using air tools to tighten everything back up ! What specs is the mount suposted to be tourqed to ? thanks for the quick responce Jason !
Old Apr 28, 2002 | 11:28 PM
Jason99T/A's Avatar
As long as everything is tight, you should be OK. I would just look up under the car and make sure nothing is close to the floorboard. Is this thump mainly on the 1-2 shift?
<small>[ April 28, 2002, 11:28 PM: Message edited by: Jason99T/A ]</small>
Old Apr 28, 2002 | 11:34 PM
Billy C's Avatar
Yes , on the 2-3 it it just has a slight thud ! The wheel hop is HORRABLE on the 1-2 , Of couse the fact that I have a clutch that actualy grabs may have somthing to do with it !
Old Apr 28, 2002 | 11:45 PM
Jason99T/A's Avatar
LOL, you are probably correct there. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Having a clutch that grabs does change alot of things.
What suspension mods have you done? I would look into some LCAs and some LCA relocation brackets. I have the BMR versions on my car and love them.
Jason
Old Apr 29, 2002 | 07:46 AM
Silver Slayer's Avatar
Billy,
It's about time you got that clutch in. You might check your torque arm mounting at the axle. I did not have mine at the right angle when I tightened mine down and it was still a little loose. I also noticed a clunking coming from the rear when I went forward after backing up. Also, the stock tranny mount on mine didn't look broken, when I put my poly mount in, but it was really weak. I had a similar sound from 1-2 and 2-3, but after I installed the poly tranny mount, it was gone. The poly mount also helps to reduce wheel hop. It pratically eliminated mine. I would replace the stock mount anyway.
Have fun,
Kevin
Old Apr 29, 2002 | 09:12 AM
Billy C's Avatar
Thanks Kevin , I knew You might have an Idea ! I climbed back under her this morning , everything looked fine , everything tight etc. , So I guess I will replace my mount , where is the cheepest place to get a poly mount ? And Jason , everything is stock underneith , But I guess that will have to change ! Man , It's amazing what a decent clutch will give ya ! thanks for all the help guys ! <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Old Apr 29, 2002 | 09:15 AM
try here... they always have good prices.. http://www.ls1speed.com/
Summitt is not too bad either.
Kevin
