Drill Mod huge improvement with slippage!!!
I thought for sure that when I speed shifted between gears that the clutch was slipping badly and it was time for a new one. I heard about the "drill mod" and did that tonight. I took my time and it took about 2hrs. After finishing I drove the car and the clutch pedal is a completely different feeling. There is no more restriction in the hydraulic line and it is very smooth. I HIGHLY RECOMMEND this mod for anyone having clutch slippage on a stock LS1 clutch!!!
McLeod Master Cylinder and Drill Mod Install
these are the instructions that i followed, i didn't replace the master cylinder, just the drill mod
if that link doesn't work there are other links in this forum that will work
hmm....i don't think your link worked. but if you go to www.installuniversity.com you will find it on their site. i did the drill mod when i did my clutch and all that other stuff....it is definatly the way to go
