Need part # for rubber boot on the shifter.
Old Jun 8, 2006 | 06:38 PM
seminolecjZ28's Avatar
Default Need part # for rubber boot on the shifter.
I had a PRO 5.0 , and switched to the stock hurst w/ a Lou's Short Stick.
I had cut the rubber boot to install the 5.0 and with the stock shifter i need a new boot to eliminate road noise caused by the larger gap. I CAN'T find the part number anywhere.
Also, is there a way to replace the pivot bearing- that the ball of the shifter sits in inside the shifter opening on the tranny. if so where do i get one?
Old Jun 9, 2006 | 05:55 PM
ttt.....
Old Jun 13, 2006 | 08:26 PM
ttt....
Old Jun 14, 2006 | 07:16 AM
calhoon's Avatar
I sen a PM on this . Did you get the boot?
Old Jun 14, 2006 | 09:41 PM
i didnt get your pm
Old Jun 15, 2006 | 07:29 AM
calhoon's Avatar
you got a new pm.
Old Jun 15, 2006 | 06:21 PM
8a8mfh's Avatar
10267518 is the boot that screws to the floor for a six speed. I paid $35 from GM.
Old Jun 15, 2006 | 06:44 PM
thanks, i am gonna look on gmpartsdirect.com to see if it is cheaper.
Old Jun 15, 2006 | 06:48 PM
its listed for $26 and some change but then $10 for shipping,
Old Jun 16, 2006 | 01:16 PM
calhoon's Avatar
The shifter boot is quite different than the body boot. Which is it you want? here is a shifter boot with the bushing.
Attached Thumbnails Need part # for rubber boot on the shifter.-mvc-005s.jpg
Old Jun 18, 2006 | 12:45 AM
that is not the boot that i am looking for and i am pretty sure that the bearing is not the correct one either. But thank you anyway
Old Jun 20, 2006 | 02:38 AM
bhop42's Avatar
You want the lower shift boot P/N 10267518.
