LS7 clutch installed this weekend
Originally Posted by 2000Z28M6
However I do have to replace my slave, remind me what are the steps to bleed the clutch hydraulics without removal of the master?
Thanx
Thanx
I think there are several methods to bleed without removing the master. First, the old fashioned way of using the slave bleeder valve. Can be tedious and a PITA but will work. You can also try to use a Mityvac from the clutch resevior. I've done this method before and it works pretty well (this is how I checked it earlier this week after being worried that it had some air in it). You just attach the MityVac hose to the bottom of the resevior and pump it up (be sure you have some fluid in the tube first). Pump the clutch pedal a few times until you don't see any bubbles. Or you can go with one of the 2 methods listed on LS2.com - "Buschman's method"and the "Ramos method" which are both similar.
Originally Posted by rgaynor85
so the ls7 requires no shim not even the factory one, is that how its supose to be or yours just wound up like that?
The first pic shows the shim I removed and what it looked like before taking it off - it is the green piece (Thanks to whomever I stole this pic from - I can't find the original poster). The second picture is the slave parts from the installuniversity clutch install writeup. It has the arrow pointing to the "stock" shim. The third pic, also from installuniversity has an arrow pointing to the pilot bearing but also shows where the stock shim is located - on the other side of the slave (the side pointing at the pressure plate springs, not the tranny). If you read the installuniversity writeup in that section you'll read the description for dealing with TO bearing and shims which requires messing with the slave. Someone correct me if I'm wrong about this but I'm pretty sure we're talking about different things.
Originally Posted by HavATampa
Any reason to put supports under the engine oill pan before removing the tranny? Seems like a lot of pressure on the motor mounts once the crossmember is removed. Nice write up...thanks!
honestly im confused , so when i drop my tranny and put in this new clutch do i just leave everything how it was? and put it back together
Well, It depends on the milage and condition of your slave. I replaced the slave on my 2002 car cause it was over 100K miles. It was in good condition but since lately the pedal had been sticking to the floor at high rpm, i fiured id better change it out while i was in there.
One thing I've noticed on my LS7 clutch that makes it feel like the stock unit, besides the overall pedal stiffness, is that the pedal effort increases up to the point of dis-engagement, then once past that point, it softens up. Just like the stock units. On the Spec clutch equipped cars that Ive driven, the pedal effort is the same all the way through the range of pedal travel. The LS7 unit is easier to modulate....being easier to "feel" the release point through your foot.
Concerning the master replacement on cars:
I needed a new master and slave with my LS7 swap. Car has 90K miles and started to leak from the master after the LS7 clutch package. Replaced with a new 2001+ model from GM. Shop did all the installs. Probably a good idea to replace your master while you are swapping to this clutch if you have high miles or a 98-2000 car.
Originally Posted by 97MysticZ
I know the tranny has to be removed to replace the slave cylinder, but you can put in a new master cylinder with the tranny still installed can't you??
#32
Originally Posted by GuitsBoy
Yes, you can. You will need to quick disconnect the hose from the tranny and pull the master and hose out from the top.
