Quick disconnect + Air in Clutch line ??
Old 06-17-2006, 09:06 AM
FstBlkz28's Avatar
Default Quick disconnect + Air in Clutch line ??
How much air would the quick disconnect let into the clutch line if I were to disconnect it to slide some heat protective lining over the clutch line, and then reattatch it?
TIA
Old 06-17-2006, 10:38 AM
Bryan @ Speed Inc.'s Avatar
i wouldn't think much, but you'd still need to bleed the line afterwards. just for good measure.
Old 06-17-2006, 04:12 PM
CTSmechanic's Avatar
Yep you still need to bleed the line..I've run'em on every racecar I have worked on and you still need to do it..
Old 06-17-2006, 09:41 PM
FstBlkz28's Avatar
Alright thanks guys!
Quick Reply: Quick disconnect + Air in Clutch line ??
