Ls7 clutch beatdown !
A friend of mine has 460 RWHP on his C5 with the same LS7 clutch set up as me. I drove his car, and it holds like a ****. I hit a gear with it and it locks right up. He also has 3.90s
When you rebuild the motor and or clutch, you really should be gentle on it for a couple hundred miles as if it was a new car.
I did install the adjustible master cylinder and have not adjusted it yet. My car grabs a couple inchs off the floor. It grabs great, but im going to adjust like stock where it grabs a little higher on the throw
So far it has proven to be very SMOOTH with zero chatter but also grabs great. I'm loving it compared to my Spec Stage 3 that only lasted 18K for me.
ran the car at the track last night.....26 in tall Et streets.... 5k clutch dumps....not a single problem at all! no smoke or anything....power shifted each shift...not a single issue....still really happy. car was trapping 93.4 mph in the 1/8 mile..in 80 degree weather with 80% humididy
-Chris
a bit late but .....
on the 100 shot the car made 508/485 and i had no problems spraying the car three back to back times ...clutch held all of it. no smoke...no smell...no soft pedal...clutch has about 4k on it, and its engagment is almost centered.
I loved it and will get it again in the future.
But i just sold my car today so i cant update anymore.
good luck to yall who have it.
-Chris
i'm posting this in the other thread too...
Video of it in action:
http://video.ls1tech.com/video/fc236...2a01695fba.htm
It did not hold to well on the last trip to the strip. It didnt slip bad but did not engage rapidly under WOT shifts at the track. still held great on the street tho.
ESP hearing all of the good stuff here about it
