Ls7 clutch beatdown !
Old Sep 11, 2006 | 07:11 PM
  #61
LSGunZ28's Avatar
Aha now the LS7 clutch problems begin. and how long exactly should I drive to break in the LS7 clutch? can I engage and disengage the clutch more than normal to wait less miles to break it in?
Old Sep 11, 2006 | 08:56 PM
  #62
nyteryder167's Avatar
I broke mine in for 300 miles, not babying it but not going nuts either, per recommendation from Speed Inc.
Old Sep 11, 2006 | 10:05 PM
  #63
rollinna65's Avatar
Originally Posted by mr2guru
the gto ls2 FW is different. You need the corvette LS2 FW to work with the LS7 clutch and PP.
Is this true? I was under the assumption that they were the same flywheel, inchluding the c6 zo6.
Old Sep 13, 2006 | 07:40 AM
  #64
WKMCD's Avatar
Originally Posted by Phil'sC5vette
A friend of mine has 460 RWHP on his C5 with the same LS7 clutch set up as me. I drove his car, and it holds like a ****. I hit a gear with it and it locks right up. He also has 3.90s
That's my car. So far I've got about 8k miles on it and it's holding really well. Of all the things I've done to the car, this clutch is one area that I don't even think of. I added the Cartek adjustable master almost immediately after install to set the pedal exactly where I want it. I don't track the car but I pound the living hell out of it....very frequently.
Feels like a stock clutch without the smell.
Old Sep 13, 2006 | 08:18 PM
  #65
JimMueller's Avatar
GTO flywheel is a different p/n. The only fw's I know which are compatible are the LS2 or the Fidanza aluminum version.
Old Jan 20, 2007 | 06:24 PM
  #66
HartAttack's Avatar
glad to see this thread helped some other people...
i talked to the guy who bought my car....and he still has no issues with the clutch...
something else i just remembered...i had a shim on the slave cylinder from the last spec 3 that was in the car.... that might have helped engagement.
-Chris
Old Jan 20, 2007 | 06:40 PM
  #67
cam's Avatar
cam
Any of you guys know the scoop about the paint daubs on the LS7 clutch/flywheel??
See here if you dont know what I mean;
https://ls1tech.com/forums/manual-transmission/631752-ls7-paint-marks-flywheel-p-plate-wtf.html
Old Jan 20, 2007 | 08:13 PM
  #68
bad6as's Avatar
mine has 10k on it
Old Jan 20, 2007 | 08:57 PM
  #69
SIC LSX's Avatar
10k on mine beating the hell out of speed shifts almost everyday and still barking 4th grear! with a 400+whp car
Old Jan 21, 2007 | 05:39 PM
  #70
DANSBIRD's Avatar
Maybe it was asked already... but Whats the difference in an LS7 Clutch over any other normal aftermarket clutch? I have a Spec3+ in my car now and it has 50k miles on it and is just now slipping. Its my DD and I love the way the petal feels. What is the advantage over an LS7 clutch as I'm in the market for a new clutch.
Old Jan 21, 2007 | 10:31 PM
  #71
MaxxMitchell's Avatar
Originally Posted by DANSBIRD
Maybe it was asked already... but Whats the difference in an LS7 Clutch over any other normal after market clutch? I have a Spec3+ in my car now and it has 50k miles on it and is just now slipping. Its my DD and I love the way the petal feels. What is the advantage over an LS7 clutch as I'm in the market for a new clutch.
After installing it in a buddies car because his stock one died, we noticed absolutely no change in pedal feel besides the different engagement point. And when it engages, it engages! Plus some just trust gm OEM stuff more then after market.
Old Jan 22, 2007 | 12:13 AM
  #72
DANSBIRD's Avatar
I love the stiffness of my spec3.
  #73
DANSBIRD's Avatar
BTW, how much is an LS7 clutch?
Old Jan 22, 2007 | 11:51 AM
  #74
Second_Infinity's Avatar
Mine (LS7 clutch + LS6 flywheel) is fried after 10K miles, all street driven on a stock engine with kumho crap tires. I will find out more on Thursday.
Old Jan 22, 2007 | 12:00 PM
  #75
SladeX's Avatar
the LS7 clutch won't work with a LS6 flywheel....
LS1 and LS6 flywheels are similar, LS2 and LS7 flywheels are similar. LS1/LS6 = Gen 3, LS2/LS7 = Gen 4. All will bolt into a LSx type engine, but I was sure the LS7 clutch/pressureplate needed a LS2 style flywheel. I recall my LS1 flywheel was flat while the LS2 flywheel was indented. I didn't try linging them up, but from eyeballing it they were meant to mesh with the proper gen clutch/flywheel.
Old Jan 22, 2007 | 12:04 PM
  #76
SIC LSX's Avatar
yup thats why its fried! You do not use ls6 flywheel! That was your problem! you use LS2 flywheel! sucks that you did that and waisted a good clutch
