McLeod Single Disk Problems Help!!
Installed the McLeod single disk and master and the pedal feels fine but the car has a hard time going into gear. Reverse also is very difficult, actually the most difficult by far. For the record I have a 04 GTO and McLeod said I was the first in a GTO. They at first sent the wrong master then had to get a shim from a spec 3 clutch because McLeod did not send any. As I said Pedal feel is fine but it does not like going into gear. Help me Please!!
Originally Posted by wrencher
Yes you have to adjust the pedal. If it has too much free play it will not be able to compress enough fluid to release the clutch.
And is there a thread or could you explian how this would be done. Sorry I am a noob at clutches.
