Black muddy inky stuff in hydraulic resiv.
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Lately my 6 speed has been acting up. I raced it this past weekend in the hot weather and yes i have headers and no i dont have my hydraulic line wrapped. I didnt know about this being i just bought the car.
My clutch slips in 3rd gear and up under load. I was told to check my fluid and yes it has inky stuff settled in the bottom. My question is how do i completely flush this system i have read how to bleed the air out with pumping hte clutch then cracking the 7/16" nut above the line going to the tranny. But how do i get rid of this other crap first besides dumping the master right? THe master is the resivoir behind the brake master right?? I am new to this.
Please give me your opinion
THANKS!
THANKS!
Hard way, but most effective is to take the tranny out and take out the slave and bench bleed it, since your clutch is slipping that wouldnt be a bad time to change the clutch. Or you can just pump the hell out of it with the bleeder open and run all new fluid threw it. More than likely it will turn black within the next week after that anyway. Mine pretty much stays black.
Senior Member
What fluid are yall using? I had this problem before and I got rid of it. I used a DOT4 and DOT5 fluid for the clutch and they both had black **** in the resivor and the clutch worked like ****. I flushed the whole deal with normal DOT3 (not synthetic) and Ive never had a problem since and the black stuff is gone. I did some reading before and IIRC the DOT5 fluid will eat rubber and thats what the residue was, the rubber mositure barier being eaten.
i had the same problem with the clutch acting up so i replaced the fluid and it didnt help so i replaced the master cylinder and now its like new. later i took the old master cylinder apart and whole inside was gummed up with that stuff. Im assuming that all that black stuff was making mine stick. when i replaced mine i wraped the line and used wilwood high temp brake fluid.
thanks guys-
im gonna try flush it tonight...either with a turkey baster or pump it and bleed it from the tranny.
its a 7/16" above where the braided line goes in right??
hope it works
hope it works
Not to sound like a wimp, but flushing the fluid doesnt look easy at all the master is buried by the brake booster. And the bleed valve if im right is on the top of the tranny...i only had the car up about 8 inches that sucked so i didnt bother with that setup....
I had other things to do..my oil consumption problem.
What do u guys do, to flush this the easiest???
Is it a waste to take to a dealership? how much?
the bleeder is not on top of the tranny its about 3 to 4 inches above where the line goes in for the slave there both on the driver side of the bell houseing. what i did to flush it was to just keep bleeding it to ensure that there was no posibility of air being in the system and just kept doing it until i saw new fluid
Like Summit2345 said, the bleeder valve is at about the 10 o'clock position on the bellhousing if you're facing towards the front of the car. To clean the black stuff out, first suck out all the fluid in the reservoir (not in the little hole in the center though) and clean up the reservoir with a clean shop towel. Once clean, fill the reservoir up with clean fluid (make sure not to pump the clutch pedal before filling up the reservoir!), then bleed through the bleeder valve to get any old fluid out. Then you can bleed the system for any air bubbles. After you've done this, wrap the clutch line in heater hose and run it away from your exhaust. Your fluid should stay pretty clean after this.
Senior Member
Thats how I did it.
well guys-
That job isnt bad at all with a helper. U have to be a little bit nimble with your hand but my flush went well. The hydraulic fluid was black now clean.
BUT..it slips all the worse.
Needless to say the tranny will be coming out...i would guess its the pressure plate..they have a bunch of springs that could slip right? I did miss a shift b4 i went racing that could have weakened it.
Any good ways to take tranny out? Easy?
If its the pressure plate which is a stage III spec...what do i put back in?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Tranny isn't real hard to take out, actually. Well, as long as you have an extra set of hands helping you out so you can control the tranny when it's coming down. Now prying the bellhousing from the block, that is a whole other story. I used a regular 4 ton jack with a piece of 2x4 and had an extra person helping me out. This was done with the rear tires on rhino ramps and the front up on jack stands.
I have 'em available and have sent several out to others. I use one and they work great. I'll PM you w/details.
Steve
Steve
Originally Posted by Country Boy
Where would one pick up one of these?
