View Poll Results: What do you do?
+ I dont think there's anything wrong with powershifting, I do it all the time.
19.25%
+ I do, but not that often, I think it takes a toll on the clutch.
43.58%
- I tried it once and it scared the hell outta me, never again.
6.42%
- Never, a clutch is not made to do that.
24.34%
- I'm a n00b ban me.
6.42%
Voters: 452. You may not vote on this poll
POLL: Powershifting
Old Dec 16, 2006 | 08:48 AM
  #121
Gsxrjack's Avatar
Originally Posted by BAD *** TA WS6
I agree with you. I just disagree with all the naysayers.
I've never run the 1/4 on my gsxr 1k, maybe I'll get around to it this year.
I'm not much of a track guy. I hate waiting 5 hours to get 2, maybe 3 runs in. That and I don't have a trailer. Which means if I break up there, I'm paying for a tow home. As well as new paint and body work on my front bumper after the tow trucks drags my car up on the bed LOL.
Everyones got their own oppinion. But powershiftings works, and its there's nothing like the fealing of nailing a perfect shift. I've got my car for one reason. To have some damned fun. I don't care what breaks, as long as I know I'm going ***** out when it happens.
I'd say I wouldn't beat on it if it was my DD. But I powershift the bag outa my '86 3 series as well.
your in nashua , im in peabody, maybe well see each other at NED this summer....
one other thing is if you look at my video , im pulling and pushing on the shifter before i shift, someone on the corvette forum called me on that and said it was a good way to bend things doing it....sure enough something is bent and grinding now, so heads up on that.....
have a good holiday to all
Old Dec 16, 2006 | 12:58 PM
  #122
SmaknaSS's Avatar
Originally Posted by BriancWS6
I used to do it ALL the time. I loved doing it and had it perfected. After my clutch wouldn't release fast enough it would grind a bit cause it was taking longer for the clutch to fully disengage, and I was ready for it to be in the next gear before it was. This took a toll on my tranny and I wound up having to rebuild it after it got stuck in 4th.
So a rebuild and new TEXtralia clutch later and I don't do it anymore. I am confident that IF the clutch was disengaging RIGHT when the pedal went to the floor and you didn't screw the shift up I think it would be ok. But the timing must be so precise that it's nearly impossible to keep from increasing the wear on the syncros.
I have gotten real good at speed shifting and have seen good results on the street and at the track, so I will stick with this method.
With that said it's the tranny, not the clutch that you should be worried about if you powershift.
My older brother would disagree with me on this.
Old Dec 16, 2006 | 07:32 PM
  #123
Bense's Avatar
Originally Posted by gametech
Wow! I can't believe this thread is still alive. The simple fact is that closing the throttle blades stops airflow briefly. This airflow must then be restarted, which takes time. Unless you are epileptic, ram the rev limiter, or are severely traction plagued, powershifting will always result in better dragstrip times. Of course it is hard on parts, if this is an issue, you shouldn't be racing.
great logic
Old Dec 18, 2006 | 11:49 AM
  #124
Genesis_26317's Avatar
I voted I'm noob ban me because I had no idea what powershifting was or did to a car.
Despite anyone not liking this thread it educated me without me having to make 2 new threads asking what powershifting was or if it as bad
Also it helped me not pointlessly try and use the search function for ten mintutes combing pages of posts that don't quite answer my question.
I got a lot of different reasons not to and a lot of examples why not to.
That and I didn't get bombarded with a-holes screaming use the search function despite the fact that I needed specific questions asked and not general info or off color answers.
I got a lot of info with the thread.
Old Dec 18, 2006 | 08:01 PM
  #125
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
So what you're saying is this thread helped???
Old Dec 26, 2006 | 11:34 PM
  #126
5w20's Avatar
Originally Posted by H/C/I Stang
Im pretty sure 5w20 gained 3 tenths powershifting
Stressful on the driveline, yes.
Beneficial in acceleration, yes.
Its give and take...
you make it seem like my regular shifting is slow
but i really picked up like .15 and ~1mph in the 1/4 mile.
