POLL: Powershifting
When I say powershifting, I mean pushing the clutch in but leaving the pedal to the metal. Basicly not letting up on the gas.
First time I went 1-2 the rear almost broke away from me....and probably would have if I had a few more ponies/torque
So a rebuild and new TEXtralia clutch later and I don't do it anymore. I am confident that IF the clutch was disengaging RIGHT when the pedal went to the floor and you didn't screw the shift up I think it would be ok. But the timing must be so precise that it's nearly impossible to keep from increasing the wear on the syncros.
I have gotten real good at speed shifting and have seen good results on the street and at the track, so I will stick with this method.
With that said it's the tranny, not the clutch that you should be worried about if you powershift.
definalty worth et since you dont lose any momentum, i could hear and see a difference in my shifts vs a normal tranny on video
