Help Haveing Clutch Problems
Old 07-19-2006, 12:17 AM
BLACKSS02's Avatar
Default Help Haveing Clutch Problems
please help me i bleed the clucth with a mity vac its got a new clucth and slave cylinder and the pedel still sticks to the floor when i am on the nitrous in 3rd and 4th. Some one told me it mite be my master cylinder could that be true all the help would be great thanks eveybody
Old 07-19-2006, 12:26 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
yeah. I bet it is the master cylinder. You can actually rupture the diaphram in the master with the mity vac, so that might be making it worse. I would get a new master before I did anything else. What type of clutch is it and what size shot are you spraying?
Old 07-19-2006, 04:15 PM
BLACKSS02's Avatar
I am spraying it with a 150 shot and its a ls6 clucth
Old 07-19-2006, 04:21 PM
BIG_MIKE2005's Avatar
LS6 clutch isn't much better than stock & comes stock in some later f-bodies I have heard. You should have stepped up alittle higher on the new clutch w/nitrous. It is probably your master with what you described.
Old 07-19-2006, 04:25 PM
Cali SS's Avatar
The master cylinder may be part of the cause but the root cause is the LS6 clutch you have. It could barely hold stock hp. Get a decent clutch and a new master and your problem should be solved. You're taking a gamble everytime you spray on that clutch.
Old 07-19-2006, 07:21 PM
BLACKSS02's Avatar
thanks guys i am going to try the new master cylinder.
if anyone else is got any in put on this still that would great thank guys.
Old 07-19-2006, 07:30 PM
BLACKSS02's Avatar
one more thing what happens to the master that makes it act werd.
Old 07-19-2006, 08:19 PM
ls1 jeff's Avatar
LS6 clutch with a 150 shot?
Even if the master does fix the sticking clutch it will be short lived.
Ill bet your spinning the clutch in the higher gears and boiling the hydraulic fluid causing the pedal to stick. Ask me how I know. As much as I didnt want to, I coughed up the cash for a Textralia.
Bottom line is your gonna need something a little more stout than the LS6.
Old 07-20-2006, 09:42 AM
Cali SS's Avatar
True words spoken.
I did the same and cough up the cash for a Textralia clutch too. I love it!
