Problem with LS7 install?
The problem the shop had was the clutch pedal having no feel/ not engaging in their terms, while they were bleeding it the old fashion way. Their were trying to pump the clutch I guess. They said the did this method for about an hour and that my car was the longest they've bleed like this with no results.
I read around different boards that bleeding takes a while and that some even vacummed it with a mityvac. Could the way they're bleeding it be the problem??
Anyway, the shop told me that I needed to get a stock clutch and return the one I bought since they said the LS7 clutch was to narrow in width and wouldnt engage as the LS1 did ( guess he was refering to the forks being raised on the LS1 and not on the LS7). I called and asked around and some trans shops & performance shops said they had problems with the install while some said its a direct bolt on. Frusterated because I should be driving her already.
The last week of daily driving in stop/go really really has brought up the engagement position. I can feel it starting to engage about 2-3 inches off the floor with full engagement at about the half mark.
I also changed the slave to an 01/02 updated one although it looked identical in size and dimension, but had a stronger spring and supposed beefed up internals. I also changed the pilot bearing and used ARP bolts on the flywheel. I kept my stock 98 master and it's been fine. I also did the standard bleed with my cousin's help, I crack bleeder, he pushed in pedal, I close bleeder he pulls back clutch pedal if it's stuck, rinse and repeat with fluid in resevoir kept topped off.
So I guess what everone is saying is that the clutch is not the problem??
Can anyone answer my clutch part# question about the LS2 and LS7 flywheel??
How would one check the hydrualic line, slave, master cylinder for it functioning properly?? BOth are new parts but the master didn't come with a braided line.
ANy help? Suggestions?/
I'll probably tell them to hook the LS7 back in even though they'll probably argue with me saying that its the culprit for the clutch not working.
Just something fior you to compare to.
I used the mity vac & it was done in about 20 minutes. Tell them the clutch is NOT the problem. It will engauge right off the floor at first, but after a few hundred miles it will be back at stock height.
I read somewhere that the flywheel is installed different from the stock ls1
flywheel?? Is this true?? I know that its thicker. Could this be the reason
the slave is not reaching the forks on the clutch if this is "the actual problem??"
Are the Pressure plate and flywheel bolts bolted differently??
Or could this just be the hydraulic line? Bad slave? Or maybe just more bleeding?
I turned the car on and tryed to get it into gear but the clutch is not engaging at all. The clutch pedal pops back up though so there has to be some pressure their. The mechanic told me that it went into gear on the rack while lifted up.
Called MTI and they said its a direct bolt-on with stock hydraulics. Didn't tell me anything about anything thats done different when installing it.
Im thinking maybe the slave is pour quality?? Heard stories about slaves from autozone going out quick. Does the dealerships slaves really have less problems??
Is their any shim needed or different slave needed for the install??
Heard other people saying theirs engages right off the floor at first but then returns to stock after driving it. The local shop told me that could damage the synchros in the tranny.
Right now I'm tight on cash and don't know if I want to take it to another shop but if I do it'll be MTI in HOuston (thats gonna be pricey). Maybe I can luck out by the problem just being the bleeding.
They may have also installed the clutch wrong? Probably not. It's safe to assume any half decent garage has preformed their number of ls1/2/7 stuff before so they should have a feel for it.
Also, check part numbers to ensure you actually recieved the correct eqipment.
If it will go into all gears while the car is turned off then not while its running, it needs to be bled. Thats exactly what mine did on my install. After bleeding it worked perfect. I'm starting to think these guys are doin something wrong. We did my clutch in a driveway at night & got it right the first time. I don't understand why they are having such a problem.
The LS7 clutch/LS2 flywheel combo is a practically stock install. No shims, no fancy parts needed, just replace what needs replacing and go. For me I replaced pilot bearing (stock one looked brand new with only 70k on it), replaced slave to 01/02 slave, (new throwout bearing comes on it), replaced flywheel bolts to ARP bolts, red locktite on the flywheel bolts, reused pressure plate bolts, blue locktite on them. All torqued to spec properly.
After we bled it and I started it up, no problems. It grabbed immediately off the floor but not bad enough that I couldn't drive it. Heck I didn't even stall it once until a week later when it was nearly back to it's old position, I was careless trying to do a u turn on a small street.
I didn't swap out the master cylinder with a new one. Is this a good idea? How are the 01/02 masters different?
