problems with the trt clutch (clutch masters)
so i bought this clutch because it was supposed to hold 700 hp ?
my car dynoed 591 but its running less than that as i got a stock bottom end and now running 8psi
so clutch has 1200 miles tops and its slipping now =I
has anyone had this problem ? and what to do
I didn't know clutch masters made LS1 clutches...even under another name.
I had a stage 3 in my prelude and thought it was VERY nice. I have always heard clutch masters made AWESOME products.
Was the 700hp a flywheel rating? If it was, you are exceeding its limits at 591.
If there is a defect in the clutch, or an issue that caused premature wear, then it will be warrantied. As with any other clutch, wear is not. Please call so I am able to remedy the issue if possible.
