Anyone out there using an aluminum flywheel on a cammed M6 ?
Old 07-30-2002, 10:03 AM
StevieZ's Avatar
Default Anyone out there using an aluminum flywheel on a cammed M6 ?
Do you have any idle issues and is the neutral gear rattle worse?
<small>[ July 30, 2002, 10:04 AM: Message edited by: StevieZ ]</small>
Old 07-30-2002, 11:16 AM
99WhiteSS's Avatar
Default Re: Anyone out there using an aluminum flywheel on a cammed M6 ?
I had a little bit of an excessive rattle noise at idle. Took the flywheel out and had it machined. Went away.
Old 07-30-2002, 05:48 PM
LSX Mechanic
Damian's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by StevieZ:
<strong>By machined , do you mean balanced?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Machined = cut..
Just like rotors, a mircon layer of material is cut away from the flywheel giving it an even and "balanced" surface..
Josh
Old 07-31-2002, 12:03 AM
StevieZ's Avatar
Old 08-01-2002, 08:20 PM
11 Second Truck Club
2bseen's Avatar
I have have no problem with my alum. flywheel some people say if you don't have alot of torque the it will stall on launch, no rattles
Quick Reply: Anyone out there using an aluminum flywheel on a cammed M6 ?
