Slave replacement coming up
so you can put the bleeder screw allmost anywhere you want.
pressure plate 70 N-m or 52 lb ft
transnission bolt 50 N-m or 37 lb ft
drain plug 27 N-m 20 lb ft
transmission mount bolt 48 N-m 38 lb ft
transmission mount nut 105N-m 77 lb ft
transmission support bolt 57 N-m 42 lb ft
engine flywheel bolts
first pass 20 N-m 15 lb ft
second pass 50 N-m 37 lb ft
final pass 100 N-m 74 lb ft
and just for the hell of it the oil filter is rated to be at 30 N-m 22 lb ft lol
https://ls1tech.com/forums/manual-transmission/627928-clutch-install-02-a.html
