Ive about had it...Please help!!!
Old Dec 30, 2006 | 07:38 PM
trey04gto's Avatar
Default Ive about had it...Please help!!!
So amongst every damn thing that has been going wrong with my car including brakes,and motor being screwed, tonight I got in my car and the thing wont go in gear!! ANY GEAR!! I tried pumping the clutch, rolling the car backward, etc and nothing!! Finally forced it into reverse and drove around the block. Once moving I could shift all the gears but it was difficult. CAN ANYONE PLEASE GIVE ME SOME INPUT ON THIS??!! Thanks in advance!!
Old Dec 30, 2006 | 07:45 PM
wrencher's Avatar
wrencher
How does the pedal feel? Mushy or lots of play?
Checked the fluid level/condition of the clutch master?
Old Dec 30, 2006 | 07:50 PM
trey04gto's Avatar
Pedal feels completely normal, although it has always been a little mushy. Fluid level is full.
Old Jan 6, 2007 | 02:50 PM
03 BUSA's Avatar
Possible issues
1. air in the lines
2. clutch is gone
Old Jan 6, 2007 | 07:33 PM
vidal77boxing's Avatar
sounds like a pilot bearing. i had the same problem
Old Jan 6, 2007 | 08:46 PM
03 BUSA's Avatar
How does a pilot bearing cause this? Usually a pilot bearing make noise with the clutch depressed. I have never seen a pilot bearing cause a hard shifting issue before.
Old Jan 6, 2007 | 11:16 PM
Revelation Z28's Avatar
im having the pilot bearing issue right now.
if it gets bad, with the clutch in, itll make the input shaft spin at or a little below the eninge's RPM and the synchros wont mesh up great which will cause the hard shifting.
Old Jan 7, 2007 | 12:53 PM
03 BUSA's Avatar
I did not know that. Thanks for the info. I will remember that in the future.
