McLeod Organic/Kevlar clutch installed!!
What's up Chad <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> glad everything works now!!
<small>[ August 16, 2002, 08:40 AM: Message edited by: Ben99Z28 ]</small>
Mike- I knew I recognized the screen name. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I will email you details of my clutch saga as its a fairly long ordeal, lol. As far as shims go, the McLeod clutch doesn't come with any. Use a adjustable McLoed master cylinder(which you will need anyway) to change your engagement points. This eliminates the need to shim the slave cylinder. You ordered the complete assembly (flywheel included) correct?
I'll shoot you an email later.
Hey Ben, whats up man? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Do you have your new setup installed yet?
Yeah Chad I got the whole setup. Flywheel, Clutch, Adj. Master Cylinder. I even got the GM 01/02 slave cylinder.
Is there any adjusting that needs to be done while the tranny is out? What I'm hoping is I don't have to keep putting it on and taking it off to make minor adjustments.
Mike
Mike
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by buschman:
<strong>Yeah Chad I got the whole setup. Flywheel, Clutch, Adj. Master Cylinder. I even got the GM 01/02 slave cylinder.
Mike</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No adjustments while the tranny is out. I will shoot you a detailed email this afternoon after work. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
