pilot bearing
im gonna take the flywheel off, resurface it, take the pilot bearing off, and do the rear main seal while im at it. anything else i should look for?
If it grind shifting has to be a release issue somewhere.
What do you mean the T/O bearing knocks??
That might be your problem? The T/O should be new w/ the new slave cylinder.
the LT1 T56 has an external slave.
well when i put the clutch in, no matter how long its in, if i shift very slowly or holt the shifter 1/2 way in gear ill feel the gears and itll grind. i was thinking its the pilot bearing binding up. its been like this since i bought the car. kind of hard to get into gear (especially 2nd)
the throwout bearing makes noise you can really hear it underneath the car.
I have fairly new hydraulics and a fairly new clutch and have bled them to death. I still cannot shift into gear at high RPM's.
You have a release issue, if it has been that way since you got it, sure the hydraulics are correct? Things typically dont stick to keep it from releasing in the fork/ T/O bearing area.
Your tearing the trans up on to of that driving it like that also.
Have you tried to flush the fluid on the master/ slave at least, might help it out signifigantly.
my hydraulics are 4 months old... new fluid when i put the mew master and slave in. new clutch fork too from when the old owner put the clutch in. im 90% sure its the pilot bearing.
