What master cylinder?
Ok so I will be gettin a tranny rebuild from t56rebuilds and will add the 01-02 slave to the tranny and i also will be gettin the exo-skel. My question is, what master cylinder should i go with? I have heard that the mecloud adj M/C should not be used with the exo-skel. Is this true? If it is, should i just replace it with just a new stock m/c? Thanks
Here is my 2 cents.....Textralia does not want you to use the adj mc with their clutch..Put in a new 01-02 gm mc and do the drill mod if you haven't done so..also, put in a new slave while you're at it....
ya... twin turbo from speedinc, 800 to the wheel hopefully with the LQ9 block. should be done within a year from now. Im just building tranny, rear, suspension etc, before i make all the power.
