transmission removal
Old Jan 4, 2007 | 06:26 PM
seppels1's Avatar
Default transmission removal
do i have to take the whole transmission out to get the slave cylinder
Old Jan 4, 2007 | 06:29 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Yes you do. That's not a fun job...been there. Have the scars to prove it. The slave is attached to the transmission with two small bolts, so there is no way around it.
Old Jan 4, 2007 | 06:40 PM
seppels1's Avatar
is there any site where they actually show how to do it.i'm doing it with a friend.
Old Jan 4, 2007 | 07:01 PM
Krab's Avatar
Here you go. It doesn't have any of the torque specs though.
http://www.installuniversity.com/ins...sity/index.htm
Old Jan 4, 2007 | 07:08 PM
seppels1's Avatar
thanks man. where can i get the torque specs though
Old Jan 4, 2007 | 09:04 PM
Krab's Avatar
Here are some of the torque specs you'll need.
Flywheel to crank bolts: 74
Pressure plate to flywheel bolts: 54
Bellhousing to engine bolts: 35
Transmission to bellhousing bolts: 26
All values are in ft/lbs.
Old Jan 4, 2007 | 10:57 PM
01Cmaro's Avatar
Hey man before you torque those things down are you running a v6 or v8? Because those specs are WRONG for a v6
Old Jan 5, 2007 | 07:43 AM
calhoon's Avatar
You do not have to remove the bell for that change.So NO you do not have to pull the whole thing.
Old Jan 5, 2007 | 11:55 AM
Krab's Avatar
Torque specs posted above are for a T-56 equipped f-body.
