T56 c5 gearbox into a f body housing
Hello,
I reacently bought a t56 housing for a f body on here and I was wondering if a C5 gear box would work in the f body housing? A guy at my work has a c5 gearbox that he is willing to part with.
Any input would be great.
Thanks
Thanks
Originally Posted by formulamd
Hello,
Thanks
Thanks
Les
The C5 input shaft is 1 inch too short.
I would think you could use the original fbody input shaft, but you wouldn't be able to use the 3 piece synchro rings that the Vette tranny uses. The GTO input is the correct length, but it only has 29 teeth, instead of 31. Like mentioned above, the mainshaft would have to be changed to an LS1 fbody style or GTO. It would probably be more trouble than it's worth. You might as well just put in a GTO tranny. All you have to do is change out the metal cup piece where the shifter ball goes. Hope this helps!
