Pressure Plate "fingers" bent in
Finally pulled the trans while dealing with this issue: https://ls1tech.com/forums/manual-transmission/641743-felt-weird-pop-now-clutch-doesn-t-work.html
The pressure plate has two "fingers" that are bent in..
![](http://www.laurben.com/host/files/1/Photo_012807_008.jpg)
![](http://www.laurben.com/host/files/1/Photo_012807_009.jpg)
![](http://www.laurben.com/host/files/1/Photo_012807_010.jpg)
The hydraulics look fine. Is there any way to reset the PP? I was able to pop the prongs back out some by my foot.![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Can I replace JUST the pressure plate on the setup? The disk and flywheel is still perfect. (and money is extremely tight right now) Anyone know the P/N for just the plate?
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
