how can i take off the hydraulic hose from the master cylinder to the slave??
i am having trouble taking the hose from the slave cylinder .. the one that goes to the master cylinder i was trying to bleed the system?? any hints, steps on how to bleed the master cylinder?? thanx
There is a green colored sleeve right next to the slave that you have to push in while pulling out on the hose a pair of needle nose pliers will work. And there are numerous threads on bleading the master.
