Can we use the new viper Tremec TR6060 trans????
ok lets look at what we know
2009 camaro. iedepend suspension. shifter looks futher forward then 4th gen. two peice drive shaft.
here i aint going to argue.
i know the new tremec ls1f-body repalce meant bolts right in. i can use my shifter/ everything. and it is 2700 for a built trany that is pretty much better then a viper upgraded t56.
go a head and spend half. 1350. then replace what is broke. and mod it to fit.
i will buy mine and just bolt it strait in.
The T-6060 should work with an LS1 F-body as long as you get a matching flywheel and disc, since it is being put on the LS3s in the new Camaro and Corvette. And if not, who really cares? The T-56 is more than perfectly fine!
but tremec has amde a bunch of 6060, one that is in new vete, one in new viper, one in new shelby, one for G8 and caddy, and replace ment for f-body,
hear, i siad it twice now. i am dont saying it. any questions, call d&d, they are tremec dealer.
I don't know of anyone personally that's opened up a T6060, so I can only speculate. I've even spent a few weeks with Tremec and dealers trying to get manuals on them, without success.
I can imagine some of the same issues with the T56, being there on the T6060 (worn fork pads, broken synchro keys, etc.) so that while having a higher initial power rating, it still won't offset the need for being rebuilt stronger.
I've seen plenty of "800hp" viper T56s get taken out by a broken synchro key. The T6060 will be a nice option for swappers, but I don't see it as a panacea. You can still buy brand new GTO T56s for $2000+, but it won't be as good as a rebuilt unit with all the extras, for less $...
My $0.02
My $0.02
I called D&D today and they have them now! just got them in this week.
Sounds like the trans to buy if you haven't already bought a T56.
One thing I really like was it comes with both mechanical and electronic speedo outputs!
Support those who support the forums!
