Clutch making weird noise. please help.
Ok, I have a 2001 camaro Z28, with a star stage 3 clutch, stock master cylinder. sometimes when I release my clutch pedal I get like a litle squeak, or more like a littl farting noise out of the car somewhere. doesnt do it all the time but it really sucks when you got a fine chic in the car with you. what is it? how can i get rid of it? TIA
I got the same problem. Get down under the dash of the car and look where the clutch pedal is. When you push in the pedal a little rod goes back and forth through a hole in the firewall. This little rod has like a plastic rubbr sort of covering probably to keep the cabin sealed. My rod on my clutch pedal rubs mine and squeakes wheneer I let out the clutch.
