Spec Stage 2 break-in question...
Old Feb 21, 2007 | 12:57 PM
JLSain's Avatar
Default Spec Stage 2 break-in question...
How long did you guys go (those who had a stage 2) before the annoying "chatter" went away?
Old Feb 21, 2007 | 02:03 PM
JLSain's Avatar
ttt!!
Old Feb 21, 2007 | 04:05 PM
blitzed96's Avatar
I have put probably about 4,000 on mine being easy on it for the first few hundred. Spec said it could take a couple of thousand but mine still does it in reverse when i'm slipping the clutch.
Old Feb 21, 2007 | 05:28 PM
transamws6_97's Avatar
it is suppose to have a little bit of chatter. It is a more aggressive clutch than stock and that is why. The normal break in time for a spec stage 2 is about 500 miles. I love my spec stage 2
Old Feb 21, 2007 | 05:43 PM
wicked z28's Avatar
500 Miles Break In, And Three Years Later And Loveing It.
Old Feb 22, 2007 | 07:40 AM
JLSain's Avatar
I love the fact that my clutch pedal pressure feels almost like stock with a tad bit more pressure!
Old Feb 22, 2007 | 10:17 AM
Bryan @ Speed Inc.'s Avatar
yea 500 miles is pretty much standard on most new parts for break in... i had a spec 3 the chatter mostly went away between 200-300 miles, and i started beating on it at 480 miles... i was on the highway and there was this mustang i just had to take down. oops.
haha
Old Feb 22, 2007 | 10:20 AM
i think chatter has a lot to do with the driver and car set up. a buddy of mine had a spec 3 with an aluminum flywheel, stock 3.42 gears, and full weight... that thing chattered a lot.
my car was a spec3 with a steel flywheel, full weight, and stock 3.42's and chattered a lot less once i put a couple hundred miles on it.
installed a 12 bolt w/ 4.10 gears (after clutch was completely broken in) and the clutch felt great, and didn't chatter unless i got lazy with it. haha
