Clutch drill mod question
Old Sep 7, 2002 | 01:54 PM
RAMBIRD2002's Avatar
Default Clutch drill mod question
I saw the diagram on install university, and I understand what has to be done. Question is when I drill the clutch line do I drill thru the center of the quick-disconnect fitting or is there some way to remove the fitting and only drill the line. Or is it the other end of the line? thanks for any input
Old Sep 7, 2002 | 02:22 PM
timelord's Avatar
Default Re: Clutch drill mod question
Master cylinder end,remove it all,it's easier!!!
Old Sep 9, 2002 | 06:29 PM
Navy David SS's Avatar
Don't believe you can disconnect the actual quick-disconnect. You can also go to www.ls1info.com for more on the drill-out.
David
