need new clutch...
clutch went out yesterday coming home from work on my LT1... dealer ship quote about 3k!!!!!
so, my questions are,
1. is it hard to replace the clutch, re-install trany?
-trany is already out
2. with upgraded clutch, is a new clutch master cylinder needed, and is it hard to replace/ bleed?
3. is pulling off and putting the fly-wheel hard?
- needs to be re-surfaced
TTT!!!!!! HELP!!!!!!
2. No - you will either need a new flywheel or to resurface the one you have ($40).
3. No - but you need to have the correct tools and a Chilton manual wouldn't hurt.
Get yourself a SPEC Stage 2+, it will be all the clutch you will need and then some.
