pops out of 4th
which internal parts of my tranny are toast?
Thanks,
Amber
You really dont know T56s very well. The clutch teethon a T56 gear( all of them) are part of the gear so damaged cluthc teeth require a gear change. Jump out of 3rd&4th is a known problem with the aluminum shift fork wear. It does not need to break . It wears where in fits on the rail. The iron fork solves the wear problem and should be a part of any T56 rebuild.Broken struts( keys, dogs, whatever) will generally cause a trans to stick in gear. Although you could also have broken struts, they are not causing your jump out problem. Once a trans has been jumping out of gear awhile, the gear clutch teeth can be permanantly damaged( at the back taper) and the gear itself should be carefully examined for wear at rebuild.
i guess what im trying to say is.. rpms dont matter as much as long as i hold the clutch in long enough, which sucks to say the least.. i dont even know what its like to have a 6speed ive been shifting 2-4 for so long..
help?
or, you have a whole nother issue, like the clutch no disengaging all the way. so you are pulling it out of gear and trying to put it into gear with the clutch still in contact with the flywheel. this is what make some LS1 cars all most impossable to power shift from the factory, some will, and some will not. thats what the spacers are for with some aftermarket clutches.
