Clutch bleeding help?!?
Old Feb 27, 2007 | 11:27 PM
ChaseSS's Avatar
Default Clutch bleeding help?!?
I have the obvious symptoms of air in the hydraulic lines and need to "power vac" bleed the lines and was wondering where I can pick up the pump and the appropriate adapter for the job... ? I know there was a thread about this but I couldn't find it. Also, I need to know the best fluid to use (synthetic? or not?) and where I can pick up anything I need... any write ups on it to? Cuz I have no idea where the resevoir even is? I have been all over the car and don't know where to look? Any help is much appreciated!!!!
Thanks guys!
Old Feb 27, 2007 | 11:37 PM
Danger731's Avatar
Just to the right of the brake resevior , it's white and round about the size of a pill bottle top. It has a rubber diaphram in it that needs to be removed.
the link
https://ls1tech.com/forums/showthrea...t=clutch+bleed
Old Feb 27, 2007 | 11:44 PM
ChaseSS's Avatar
THANK YOU Danger731!!!
Old Feb 28, 2007 | 12:05 AM
ChaseSS's Avatar
is there a fluid that doesn't boil as easy? Or is better than whatever is in there now?
Old Feb 28, 2007 | 01:50 PM
ChaseSS's Avatar
ttt any suggestions? Since the engine bay gets hotter that its supposed to stock I was wanting some different fluid that would last longer without boiling thus no air????
Old Feb 28, 2007 | 02:55 PM
TheLS1Kid's Avatar
DOT 4 or DOT 5 fluid has a higher boiling point.
Old Feb 28, 2007 | 03:54 PM
Sneakyws6's Avatar
On the tree
Do not run DOT 5 in these systems. It is a silicon baised fluid and is not compatable with DOT 3/4/5.1.
Old Feb 28, 2007 | 04:15 PM
ChaseSS's Avatar
so DOT 4??
Old Mar 2, 2007 | 05:45 AM
Danger731's Avatar
Dot 4
