Just bought z06 clutch and the disk looks damaged...
This clutch is for a buddies 99z28, just received the clutch today and the disk has a bit of damage it seems. Is the clutch ok to use or should I send it back?
CLutch Disk
<small>[ September 10, 2002, 02:26 PM: Message edited by: 2000 ws6 ]</small>
CLutch Disk
I'd say ..... that won't hurt anything.
BUT
Unless you need to put it in right away, I'd still return it.
BUT
If you mean some fraying of the friction material on the outer edge of the disc, should not be a problem. Just lay the disc on the plate and site it side on to make sure it is not bent.
