WTF now i cant connect my hydraulic line!!!
is there a way to release pressure from the slave cylinder? my problem is that the hose will not connect into the transmission. it wont go in far enough so that it will connect. could this be because of my new clutch? i have the spec 3+ and it came with a shim that i was supposed to use to shim the slave cylinder and i did so. now i have everything in and ready to go and i cant get that damne hydraulic line to go in far enough so it connects.
Originally Posted by MeentSS02
Crack the bleeder screw, then try it. And as you have seen, you should not be able to move the pedal at all with the fitting disconnected.
I had this issue before and this had worked. Usually I have a hard time getting the damn thing off, and I have the special tool for it.
