Transmission Hard to shift into reverse?
My car started throwing a SES light, and the next day it started getting hard to move over into reverse. Basically if I try it with one hand like normal, I can't move it past the 5-6 space, I have to use my left hand to shove the stick over to get it lined up with reverse. It happens everytime I try and put it in reverse. Every other gear is fine, the effort to move the stick is the same everywhere else. Once you're in all gears they drive fine.
The code I'm throwing is the P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction. I've had skipshift disabled on my car for years, but I don't know if the solonoid that activates it normally just went bad. Even if the solonoid has went bad, I don't understand why that would be effecting the shifting effort into reverse.
I had recently installed a McLeod twin disk, new slave, adjustable master, but that was about 3 weeks before all this happened, and I'd put plenty of miles on it since then.
Ideas? I'm trying to see how the issues could be related, to see if that helps me fix it. Or if they're not related any ideas to why the shifting effort got higher all of a sudden.
I'm not having any problems with the speedometer.
I can't check any of these things until May. My car is parked at my parents house in Indiana right now while I'm working out in Arizona for the semester. I'm just trying to get some ideas on what it could be before I go home.
Good luck and please keep us posted. I'll do the same.
where is the fuse panel and which is the fuse for the reverse lock out?
I can pretty much garuntee its one out of these two.
