installed spec 3+
thanks
thanks
From what I gather here... '97-'01 slave and master cylinders were weak (which is why my pedal stays on the foor at the track I assume). So just go to GM and get any sc and mc from a 2002+ and you will be set. Thats what I did!
Thats probably all of your problem right there. Anytime you have a hydraulic leak you wont build pressure and you introduce air into the system and then nothing will work right! Get it fixed asap.
Its all about a good install, torqued bolts, clean parts, and proper break in.
