Missed 3rd... now this???
Now, the car won't move under power.
Symptoms:
Car running-
-----Press clutch, shifter in ANY gear, release clutch= NOTHING
-----I can row straight through all 6 gears and reverse without touching the clutch
-----When moving shifter through the gears, I hear a faint "cnch" sound between each gear
Car NOT running-
-----Shifter IN gear=car won't roll when pushed
-----Shifter in Neutral-car does roll when pushed
Centerforce Dual Friction, Stock T-56 tranny, stock shifter.
Thanks in advance for your net-diagnoses!
Could I get by with swapping the broken/trashed parts or should I swap the whole unit?
I have a used stock clutch/flywheel up for sale if you need a cheap setup. It held fine and i was hitting a 150 shot, it didnt slip. I also have a slave too. I replaced it all when i did the engine swap. Lemme know if you need it.
He says it's most likely the pressure plate is trashed. This is also the most frequent response I got on my local forum [PLUG] hsvracing.com [/PLUG].
He also believes it MAY be that the outer part of the clutch disk (with the friction material) has seperated from the inner hub.
I could see either one being the case. What do you guys think???
I'm not going to say "I don't mess up" but in my 7+ years in this car, I have YET to stick the shifter back into 1st (or from 3rd back into 2nd for that matter).
I just don't do it.
SPEC, I am fairly certain I am going with a SPEC clutch, are you associated with SPEC?
