Stripped nut on Adjustable master-clutch hell continues for me
After my whole RAM fiasco all of a sudden my car wont go into reverse with the car on (car off goes right in). I figure no problem the master just needs to be adjusted out more. Try to loosen the bolt and try and try and try. WTF? I was so fed up I was at the point of just trying to move the bolt and didnt care if I bent the whole rod. No luck, take a closer look and the bolt is crooked on the rod....screwed. I dont understand why they even have this on there as it not going to move on its own when the clutch pedal is hooked in anyway.
I ordered a mcleod adjustable master from Thunder and I am hoping that this master cyclinder will fix my high RPM shifting problem also.
