Remote Clutch Bleeder
Here is a complete parts list to build yourself a remote bleeder:
Everything is from Summit.
AER-FBM2937
Fittings, Brake, Steel, Zinc Plated, Male -4 AN to Female 3/8 in.-24 Thread, Inverted Flare, Pair
(Quantity = 1 of the above item)
EAR-177100ERL
Crush Washers, Crush Washers, 10mm Fitting, 10mm I.D., Aluminum, Set of 5
EAR-64191936ERL
Brake Line, Speed-Flex, Braided Stainless Steel Hose, Female -4 AN to Female -4 AN, 36 in. Long, Each
(Quantity = 2 of the above item)
EAR-9919BFDERL
Fitting, Adapter, AN Flare to Metric, -4 AN to 10mm x 1.5 Male, Aluminum, Blue, Each
RUS-639590
Brake Bleeders, Speed Bleeders, 3/ 8 in.-24 Thread, 1 in. Overall Length, Steel, Pair
NOTE: With the above quantities you will be able to build 2 remote bleeders. (I did this because 2 of the parts above are sold in pairs) You can just sell the second remote bleeder on here and that will save you some money.
Total Price = 96.12
Price per bleeder = 48.06
ADDITIONAL INFO
When installing you need to use -AN wrenches, do not use metric or "english" sizes. If you don't have -AN wrenches then adjustable crescent wrenches will work fine. (-AN is a different size than metric and "english." If you use metric or "english" you risk stripping the fitting)
Keep in mind you will also need thread sealant and brake fluid for the install.
Last edited by brad8266; Apr 13, 2007 at 11:31 PM. Reason: Removed non-sponsor link
Vacuum pump bleeder, link was removed(non-sponsor)
Last edited by brad8266; Apr 13, 2007 at 11:34 PM. Reason: removed non-sponsor link
Talk to Pete at Textralia and he will tell you to bleed it the traditional way.
I have a remote bleeder setup and it was almost too easy to use. The speed bleeder is what really makes it error proof.
Last edited by brad8266; Apr 14, 2007 at 04:53 PM. Reason: removed product info(non-sponsor)
Direct off L.A.P.D's site (one of the largest manufactures of remote bleeders in the after-market T-56 world)
Last edited by brad8266; Apr 14, 2007 at 04:54 PM. Reason: remove non-sponsor link
Yep, I will do or say anything to make a sale. If you say so bud. My feedback proves it too.
Youre just pissed because we proved you wrong on your idea of a 90* fitting coming off the slave for a remote bleeder for a f-body.Im not going to argue with you here either. Its the peoples time and money. They can decide for themselves. Ours is proven and works.
btw, before you make anymore claims, look up slander.
He will do or say anything to make a quick sale.
Second we are all using the same slave cylinder bodies. So a crush washer will work fine in all applications. And if I am not mistaken you are the one being proven wrong. You are the one following me around and you are the one who does not know when to shutup.
Third I am not making any money on this, you are making money on the remote bleeders you are selling. What motivation do I have to lie? Seems like you and your father are pissed that I have presented a parts list that is far cheaper than what you are charging. You think you can stop people from doing it themselves by placing some sort of doubt in their head. Your father saying that you "apply a special coating to the threads" when all you really do is put some regular old thread sealer on there. You saying that "A crush washer will not work" when that is what everyone uses and that is what they are meant for. What will you guys come up with next?
I have provided you with hard evidence that a crush washer will work fine. You decided to ignore that and say "Ours is proven and works." Wow that's mature. You may have 21 feedback, but why don't you call L.A.P.D or C.A.M and ask them how many hundreds of remote bleeders they have sold/installed with crush washers.
P.S. It is not slander when it is true
Please stay out of my thread. Start your own if you fell you must.
I used to use a 1/4" socket and ratchet to open and close the stock bleeder. Yes, its a big PITA.
The F body and Vettes are completely different in respect to bleeders. Yes, a 90 will work on a vette but not a F car.
1st off I do not like to vacuum bleed. I think good old "gravity" bleeding is the only way to go.
2nd It sounds like you cut into your bell housing... I would not do that too my car.
3rd never reuse old brake fluid!!
Why don't you put some thread sealer on your bleeder screw? (I am talking about thread sealer NOT thread locker)
Here is how you should bleed:
Crack bleeder screw
Press clutch to the floor and hold it there
Close the bleeder screw
Release clutch
Refill master cylinder reservoir
Repeat all the above steps in order until you are happy with engagement. (maybe 10 times...)
Dave, If you have anymore questions please start a new thread. What you are talking about really has nothing to do with a remote bleeder.
