Help ASAP
Most cars I work on these days have external slaves.
I will check the slave in the morning but where is the master located at exactly? I'm relativly new to these cars.
There is a rod that connects to the pedal. Follow that & that is the master, see if it is leaking there & into the car on the carpet.
If you fill it & it leaks out the bell housing then you need a slave.
did the pedal go away slow, I'm betting it is a master.
Good luck!
Good luck.. again. lol
