Short throw shifter
ok, well i know im getting a short stick, so is it worth is to get the pro 5.0 as well? i just want to be able to hit 3rd easier and have all around better shifting.
Do you ever have problems missing 3rd gear? If you do, get the Pro 5.0 and you shouldn't ever miss it again. The 2-3 is beveled so it shoots right into gear. I love mine. It was a substantial difference over the stock non-Hurst shifter.
Originally Posted by Kavslayer
I bought a after market hurst billet shifter(was told at a later date that they were really hard on the Shift forks) and its REALLY tall. If i buy a WS6 store short stick will it bolt to the after market hurst?
Originally Posted by A-man930
Ditto. The Hurst stick is really tall and since it isn't round You cant just cut and re-thread it... will the LSS or WS6 short stick work with my Hurst?
I cut over an inch off of the Pro 5.0 stick that came with the shifter and it's perfect. Other short sticks with the Pro 5.0 shifter just don't work as well. The Pro 5.0 Power Tower is basically mounted off-center compared to the stock shifter and therefore a straight stick does not work well enough. The Pro 5.0 stick that comes in the box is angled and works perfectly with at least 1" cut off of it.
Just put the stick in a vice and use a hack saw with a fine-toothed blade. Cuts right through it. Then use a file or a grinder to bevel the edges of the threads so the shift **** goes on easier.
