Should I Rebuild My T56 Myself?
I am pretty much mechanically inclined. Is it really hard? Anyone have any pointers? I would like input from others that have done it theirselves to.
If you like to DIY stuff, go for it. But you cant get mad if you dont put it together right. If you pay someone else to do it, the responsibility is in their hands. You would be better off, pulling the trans and letting a professional rebuild it and then put it back in yourself.
I am a diy guy. I built my motor and done lots of heads and cam swap for me and friends and etc. I just need to know what kind of task to expect. My tranny was rebuilt about 10k miles ago. Could I just replace 2nd gear without taking everything else apart?
you pretty much will have to dissasemble the entire mainshaft gears and if you dont know the proper clearances and have the tools to put it back together properly it will be notchy or wont last as long, but that being said, i rebuilt part of mine one time but i didnt have to change anything major on the shaft.
What all would I have to take apart to get to 2nd gear?
Instead, he told me to come over cuase he had just finished totally disassembling one and it was sitting on his gerage floor.... I said, cool, i'll come check it out... boy was I in for a suprise.
I had no idea that a dissassembled M6 transmission could take up 50% floor space of an almost empty two car gerage. after I saw that, I was like....**** that, i'll just pay you!!
you need special tools from what he told me too. I'm pretty much mechanically inclined....I can pull a motor out of a 4th gen and put a new one in about a day...with no air tools or lift and only one person helping me. But i'll be god frikin damned if I EVER take apart a transmission without proper training to do so, haha.
and a torch to get 5-6 driven gear off, if its seized on the mainshaft. A press is good for 1-2 and 3-4 synchro assembly to get into place. But it may just slide on there, mine didn't.
Oh also a good bearing splitter is your friend.
If you've got the time to not rush it and possibly having to order parts and wait for them isn't a problem then it's a matter of the tools. Good set of large snap ring pliers, press (or access to one), possibly bearing seperators, gear pullers with fairly long arms, and proper guages if you need to reset input shaft end play or countershaft pre-load. I was intimidated at the idea, but the reality is that it's not that difficult. If you have all the parts and tools it's really a couple hours once the trans is out.
I agree with the DIY guys.
Try it out if your mechanically inclined. Get some good manuals and do a lot of reading and looking over diagrams before you dig in. Proper tools and an organized work area make the job seem orderly.
