LS2 and Z06 Clutch
Are you talking ls7 Z06 or ls6 Z06. I would not recomend the ls6 as that is what came in 01-02 camaros and will light mods they tend to eat those clutches up. The ls7 is the clutch you want and should do just fine on a lightly moded or stock GTO. Yes the ls7 with work with the ls2 without a problem.
The reason I was asking is that someone wants to buy my Z06 setup; flwheel, pressure plate, and clutch disc - only have 4,000 miles on it.
He has a 2005 GTO. I believe it will work for him since he will be changing the flywheel along with the clutch. I just wanted to make sure that the LS6 Flwheel would work with the LS2 in the GTO
