T56 locked me out of all gears???
You can use these...
Spec Flywheels @ Thunder Racing
I don't think SLP has a lightweight fly for the LS2/LS7... I could be wrong though. Don't be confused by advertisements, though. The LS7 clutch requires an different LS2/LS7 flywheel, it will not bolt to any LS1/LS6 flywheel. I think they advertise LS1 flywheels for fitting LS2's for the purpose of an LS2 using an aftermarket LS1 clutch.
Originally Posted by 99ssleeper
I highly recommend www.ws6store.com ...they are very friendly and helpful, great service and they can beat anyones price.
You'll need some boltons to beat the cobra, but the race will be closer than he thinks if youre a good driver and he's so-so. A friend of mine has an '03 that did over 450rwhp and from a stop I was still ahead into 4th gear. It has a lot to do with the driver and maybe a little luck.
thanks for the info. I called slp and speedinc and got the same anwser from each an ls7 clutch takes a ls7 fly wheel.
learn something new everyday. the fly wheels you have linked to should work based on what I have learned today.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
