clutch guru's help...
Its not to bad shifting between gears now, but from a dead stop or rolling when i let the clutch out of first it seems to want to die and i have to give it alot of gas and then if i dump the clutch it will bog and go, but still not grabbing like i used to.. I tryed adjusting the MC and moving the rod closer to the firewall but still no good. Its making a high pitching moaning sound and its annonying.
Ive only had this clutch for about 4,000 miles , recently replaced from a current cartek that took a dump on me... I dont want or have funds to get a new clutch, its not that old and having to replace clutches every 4-8,000 miles on a car that sees the track maybe once a month is crazy... Sorry for long post, just thought i would try and get some ideas from you guys.
