Reinstalling the hydros.. quick question
I wasn't paying attention on the tear down.. does the braided line go to the drivers side or passangers side of the steering shaft?
under steering, and behind the end of that upper heat sheild. And if you have LT, somtimes I re drill the holes for the lower heat sheild to move the heat sheild torwds the outside of the car to cover the line more. Its not a bad idea to give the line a alumfoil then heater hose wrap for a getto heat sheild itself. If you have clutch pedal/fuild boiling/getting dark problems.
