High RPM Shifting? Problem! Help!
2. What year slave and master are you running?
3. Are you running the stock MC?
1. Drill Mod is done.
2. 01-02 Slave Cyclinder and a Ram Adjustable Master.
3. Ram.
I forgot to add this is another thing. My car recently started not going into 2nd when you downshift unless you act like your going to first gear then it goes into 2nd perfectly? Is the tranny screwed?
This is a common symptom. Surprised drill mod wasn't it. Looking forward to hearing result of bleed.
