t56 rebuilders- help :).
Second- you can see my 3rd gear in the pic with the slider- would you re-use it or replace it? I have a new one here, but I'm not sure if it needs it or not. The tips of the gears do look to be thinner than the new gear though, so it may be a good idea to just swap it. It appears this trans was run low on oil by how the input shaft and cluster shaft looked. Third gear looks "iffy" to me, but not as bad as the others were.
Third and last- the 2nd gear synchro assembly- the friction cone (the inner piece that has the "ears" that are driven by 2nd gear). The ears are almost completely worn/sheared off- I apparently need a new one, but what causes wear like this so I know what to look out for? Is this available separately, or do I need the whole synchro assembly? Thanks in advance.
Joe
.JOe
. I know that no matter what he did to it stock, it will never be as hard on it as what I'm going to be lol.Joe
Joe
Good luck on the build .
Joe
