Pro 5.0 problem ???
Old Sep 23, 2007 | 09:04 PM
02SOMLS1WS6's Avatar
Question Pro 5.0 problem ???
When you move the shifter to the 1-2 gate it wont spring all the way back to the 3-4 gate when released. When I move it to the 1-2 gate and release, it will move about half way back to the 3-4 gate by itself then I have to tap the shiter for it to finish travel. This problem doesn't occur when in the 5-6 gate as it springs all the way back to the 3-4 gate when released. Any suggestions on what the problem is?
Old Sep 23, 2007 | 09:21 PM
Grifter's Avatar
Mine does the same. Not sure if it's normal, the car shifts fine.
Old Sep 23, 2007 | 09:27 PM
thesource's Avatar
How old is the shifter ?
Old Sep 23, 2007 | 09:50 PM
Ya my car shifts fine too. I went racing last week and didn't notice it at all and it shifted fine. I just think it is weird so I thought I would ask if anyone else has this problem.
Old Sep 23, 2007 | 09:51 PM
It has been in the car since Power tour, June.
Old Sep 23, 2007 | 10:10 PM
thesource's Avatar
Have you been through any water ? Maybe some of the grease has been washed out of it ?
Old Sep 23, 2007 | 11:10 PM
studderin's Avatar
so how dose it shift driving the car???? lol
mines like thats sence new, but real shifting its mint.
Old Sep 24, 2007 | 05:57 PM
Big Bird WS6's Avatar
mine is the same. i called pro 5.0 like two weeks ago. they said that the centering springs might be going bad.
now if there all of us that is having this problem. maybe they got a bad batch of springs.
either way mine is getting sold after i send it to "pro" and they fix it.
Old Sep 24, 2007 | 06:43 PM
transamws6_97's Avatar
what will you be going with? hurst?
Old Sep 24, 2007 | 08:12 PM
aw01m6t\a's Avatar
mine started doing it the past couple weeks. i figured that the springs were wearing. still shifts nice.
Old Sep 24, 2007 | 08:41 PM
blk99camaro's Avatar
Mine is the same way but ive had mine for well over 2 1/2 years now
Old Sep 24, 2007 | 09:23 PM
WS6 SRT-8's Avatar
Same here. Only a few thousand miles on it. Like everyone elses, mine shifts fine.
Old Sep 25, 2007 | 03:37 AM
nighthawk15's Avatar
Mine has only been on for a couple hundred miles, but FWIW it snaps right back where it should every time.
Old Sep 25, 2007 | 10:41 AM
ghettocruiser's Avatar
Same here... Im going to do the shim/bolt head mod to the springs to see if that helps any. First im going to do only one side...see if that helps. Might try both sides to see how it feels. Im doing some work on the car which might require removing the shifter soon...so Ill do it then.
J.
Old Sep 25, 2007 | 08:26 PM
Mine still shifts fine it is just a minor issue that I dont like about it. I would have expected a greater quality product from what I read everyone raved about it, so I went with it. I will keep it for now unless it starts to get to me more, maybe I will try the ripper if it does.
Old Sep 25, 2007 | 08:55 PM
yes hurst plus. but mine is like 1.5 year old and maybe only 5000 miles on it
Old Sep 26, 2007 | 03:06 AM
tylert14's Avatar
Mine started doing that occasionaly. I sprayed it out with brake cleaner real good, blew it dry with compressed air, squirted a little oil in it then some grease. Hasn't stuck since and it has over 7k on it.
Like I said though, mine only did it occasionaly. Are your guys feeling like there getting hung up on something (dirty mayby?) or do they just feel limp?
Old Sep 26, 2007 | 07:42 AM
m6speed's Avatar
mine did that, but then i wiped out the grease and put in new grease and worked it around and it seems to be fine again
Old Sep 26, 2007 | 04:36 PM
well more like the centering spring sucks. my car sees sun and only sun on calm days. not to much dirt. but i tried the whole cleaning thing and that didn't work. i know it is the spring.
Old Sep 26, 2007 | 07:53 PM
Mine is a garage queen also so probably not dirty. I properly cut the tunnel shift boot so it isn't possible for road grime to get up in there. I will try to grease it up better. What type of grease did you use? It came with white grease that I have never seen before on it. Most likely though it is a crappy centering spring as mine has maybe 4000 miles on it, which include power tour.
