Hurst shifter does not fit
Old Oct 8, 2007 | 10:54 AM
TARV's Avatar
Default Hurst shifter does not fit
I have a 98 WS6 and I tried to get rid of the stock shifter and swap it out for a Hurst shifter that came out of a 02 WS6 and I couldn't get the shifter to go in correctly. It wanted to sit down and to the right about two inches too far. I left the car in neutral after I removed the stock shifter. Any help on why this shifter did not work would be appreciated.
Old Oct 8, 2007 | 11:48 AM
wicked z28's Avatar
i have the same problem but i think they only go one way and im not sure if it matters what gear its in before you take it off but it seems like all the gears are more to the right now then before, let me know also if you find a solution and ill do the same.
Old Oct 9, 2007 | 07:12 AM
TARV's Avatar
Bump for some answers.
Old Oct 10, 2007 | 10:24 AM
TARV's Avatar
Anyone?
Old Oct 11, 2007 | 06:35 AM
calhoon's Avatar
That shifter should fit without a problem. If you installed the upper handle on the wrong side of the shifter stub shaft, that could be why it is out of position/ skewed.
Old Oct 11, 2007 | 07:07 AM
TARV's Avatar
Nope, handle was where it was supposed to be. Any other guesses?
Old Oct 11, 2007 | 02:26 PM
wicked z28's Avatar
same here on driver side but still off
Old Oct 12, 2007 | 09:03 AM
TARV's Avatar
Ah screw it. I just put a Pro 5.0 in it and it works fine even thought the shop that I bought it from put the stick on the wrongs side.
Old Oct 12, 2007 | 10:57 AM
wicked z28's Avatar
Yeah i guess so, are you going to put a short stick on it.i just didnt want to buy one i wanted to be cheap and by just a used stock hurst i have the lss allready.
